Problems with CAN card and exiting LabView
I have a problem with using my CAN card (EDICCard2 from Softing).
I have written a program that communicates via the CAN bus.
For the card there exists a windows API and I am calling the dll-functions with the "Call Library"-function.
The communication (receiving and transmitting) is working fine.
But if I stop the VI and start it again, the CAN is not working any more.
I have to close the VI and re-open it to reactivate the CAN-card.
From softing there exists an example for using the dll with LabView6 I have used and modified this example.
The last operation bevore the VI stops is calling the function "INIPC_close_board" from the dll.
I thougth after that the CAN card will be released but it seems as if the card is already in use.
After restarting the VI (without closing) the function "INIPC_initialize_bord" also gives back a failure.
Has anyone an idea why the board is only released after closing th VI?
Best regards
Sven
(3,076 Views)
 Hi Sven,
it looks like the CAN resource is not released in your program.
Maybe inserting a wait of a couple of ms after calling the "INIPC_close_board" will do the trick. Otherwise please contact the Softing support why the resource is not released when calling "INIPC_close_board".
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,050 Views)
