Missing vision and motion option in lab view
Hellow i download the NI Vision Acquistion software but still i dont find the vision and motion option in my lab view please see the attached file
Help Please
(4,729 Views)
Check the  version of NI Vision and the version of labview. For example, if you use LabVIEW 2013 and install Vision 2011, it will not work.
bhovhann
(4,708 Views)
ni vision version and labview version should be same
Please see the attached image, i have NI Motion of 2018, This issue may be by NI motion 18 ?
and i
(4,680 Views)
Did you installed for the same 64bit? Ensure whether it has 64bit or 32bit.
Go to NI License Manager and be sure your software is Activated.
bhovhann
(4,658 Views)
What version of LabVIEW are you using?  You seem to have NI Vision installed, but not NI Motion.  I now cannot find the reference, but I recall seeing, somewhere last month, a notice that NI was stopping development (and shipment?) of NI Motion.  This is more likely to be an issue if you are installing LabVIEW 2019, I would think ...
(4,640 Views)
am using labVeiw 2019, I have installed NI motion But it supports Labveiw 2018
(4,634 Views)
try  to use labVIEW 2018
bhovhann
(4,618 Views)
