Mitutoyo USB Interface
Contact this company, they may be able to help:
http://www.microridge.com/gageway_sm_series.htm
-AK2DM
Message 31 of 36
(1,706 Views)
Thank you very much. It's just weird that I can't use the IT-016U input tool the same way.
Message 32 of 36
(1,703 Views)
i was serching for the solution finally i got Thank you.
Message 33 of 36
(1,294 Views)
Thanks for the solution.  I was having issues communicating with a Mitutoyo 575-123 via a USB-ITN-F cable.  Nothing worked until I used the 3 VIs from Page 3 of this thread.  I needed to change the Write command from "GA00" to "1" per Mitutoyo technical help.  Other than that it was perfect for me.
Message 34 of 36
(515 Views)
We do!
63AAA029 DIGIMATIC I/F 1-CHANNEL   $137.00 list
https://my.mitutoyo.com/General/FindDistributor
Message 35 of 36
(506 Views)
The Input Tool 264-016 is a one way device. Press button on the gage, the button on the Input Tool, or use a momentary switch in the jack.
The 264-007 Input Tool for RS232 is serial data. Send it a 1 to make the request.
Message 36 of 36
(503 Views)
