Modbus RS 485 (stepping motor DRIVER LSD-CD) commuicatation with Rotary hallow system
Hello People,
                      I've Just rescently started with project of communicate with Stepping motor Driver and I pretty new to Labview as well. Now, I have already installed a MODBUS library for LabVIEW and RS 485 USB interface .
                     The Main Aim is to get a rotational motion of the hallow system. I could not able to write a Labview programe to this Task. I am really stucked and how to use the registers and all. Would you plase mind giving me necessary inputs to draw the code. And plase provide me some possible example VIs to get rough knowledge would be appreciatable.
Thank you,
Yours Sincerely,
Anil
(3,047 Views)
Hello People,
Thank you,
Yours Sincerely,
Anil
(3,043 Views)
Hello Anil19
do you found this post
Oriental Motor : ARD-KD & Labview drive
it contains some vi´s that could help.
best regards
Alexander
(2,991 Views)
