lvrt.dll path problem
I compile and run my application. There is an error message popup. Please refer to the attachment.
If you notice, there is an extra "/" beside the LabVIEW Run-Time. What leads to the problem? Thanks
I have another question. There is two DLLs generated when I tried to generate a DLL from a VI. The name of these DLLs are lvanlys.dll and lvdaq.dll. Do I need to include them as well? Thanks.
(3,462 Views)
Problem solved. Thanks for the attention.
(3,462 Views)
What is the solution to your first problem?
(2,897 Views)
