Modbus RTU Reading Issue with LabVIEW 2024
@K C  escreveu:
65554 is larger than 16 bits.
If it is 65535 than it could also be -1
Depends on the number format.
Kees
65504 = -33
65502 = -35
65512 = -24
Yes, yes — if what I wrote down isn't wrong, the values I'm seeing are pretty close to the ones you listed above.
Right now, I'm trying to apply a filter where I take the unique value from the array, and if that value is less than zero, I set it to 0. Then I convert it back into an array so it can be processed later.
But I’m having some trouble with this. Could you take a look and tell me what I might be doing wrong?
After that, I still need to figure out how to display the values properly — since it's in an array, it's not very easy to interpret as-is. I’m thinking that maybe if I handle the data individually first, and only reassemble it into an array afterwards, it might be easier to manage and visualize.
I also have to be careful with the data type — apparently it's sending the data as U16, but I was interpreting it as I16, while what I probably need is DBL.
Message 11 of 15
(1,541 Views)
The Modbus protocol only knows u16 registers, which is why the driver has a u16 output. Whether that is the correct datatype depends on the device that sends it. You have to convert it to the correct type yourself. Use the Numeric>>Conversion palette or Type Cast from Numeric>>Data Manipulation.
It is an array because you can potentially read more than one register at a time. If you read one register, you get a one-element array. You can just index it.
Is this what you are trying to do?
Message 12 of 15
(1,528 Views)
It's more or less this
I'm trying to filter the values, and if they are above 65000 — it's just because, as was mentioned, 65535 could actually be -1, so this was the best workaround I could think of for now.
Then, if the value is negative, I clamp it to 0. After that, I rebuild the array.
To be honest, I'm not really sure if this is the correct way to do it.
Message 13 of 15
(1,522 Views)
Maybe you tell more about the device that are reading.
btw. if the value is a I16 numbers above 32767 are negative.
Do you have more information about your ModBus device or post the manual here.
Kees
Message 14 of 15
(1,407 Views)
Hi Kees,
Thanks for your help! I was able to solve the problem — it turned out to be a loose wire, which has already been fixed.
Right now, when the reader receives the value, it's converted to I16. If the value is negative, I set it to 0. Then I convert the data from Newtons (N) to metric tons (tf), generate a new array, and pass it through a shift register to build the final array.
Thanks again for your support — it really helped me get through this!
Marcus
Message 15 of 15
(1,393 Views)
