Modbus RTU over TCP (Simex Transmitter and Advantech Server)
Hey Guys,
somehow i am not able to get a connection over TCP IP using RTU Mode (reading values) from a  transmitter which is hooked up to an advantech EKI 1542 Server. The Port is configured as an RS 485.
i am using the modbus library and i tried to adjust the MB serial read holding registers vi to accept a TCP IP Socket input instead of an INSTR. Do you have any suggestions?
Thanks a lot for the forum support!
Message 1 of 9
(5,319 Views)
i also tried the TCP connection vi and the MB ethernet but this gives me an error 56
Message 2 of 9
(5,318 Views)
Hi Christo and welcome to NI Forums!
Is this the ModBus library you are using? If so, I'd recomend to check out the newer, object based library available here. It has a more straightforward setup, especially for using TCP connections. You'll find an example VI for using a master, as well as a slave device, and these you'll be able to use right away without much modification. The code'll look like:
Please test your device communication using this library.
Kind regards:
Andrew Valko
NI Hungary
Andrew Valko
National Instruments Hungary
Message 3 of 9
(5,263 Views)
hey thanks for your help. i finally got it to work modifying the old modbus library so that the serial vis take in a tcp/ip socket 🙂
cheers
Message 4 of 9
(5,233 Views)
Hello! can you shared your result vis.
Message 5 of 9
(5,166 Views)
Hi Christo89
i have at the moment the same problem as you. Before starting to modify the old lib I have found your solution. It would be very nice from you to share your lib!
christoph
Message 6 of 9
(5,124 Views)
hey guys
sorry for the delayed answer.
sorry i dont have the vis at hand right now. but i can try to explain the fix
it was a pretty easy fix afterall. i opened a connection to the server with the visa open vi putting in a tcp/ip socket.
then i fixed the the MB Serial Master Query Read Holding Registers and its sub vis to take the tcp/ip socket as an input.
in the MB serial receive vi you have to delete the bytes at port property node and replace it with read visa with a byte count of 1024.
delete the upper error wiring due to errors related to the socket thing and thats it. works like a charm 🙂
Message 7 of 9
(5,118 Views)
Hi Christo89
Would you mind please share your modifieded for Modbus RTU over TCP !
Thanks and Regards
Luong.Tran
Message 8 of 9
(4,920 Views)
Date Last Visited ‎11-28-2013 10:20 AM
What do you think the odds are that he'll reply?  You'll have more luck trying to implement the code he suggested
Message 9 of 9
(4,914 Views)
