Modbus Write single coil not responding
I completed agree with you that Technical Manuals SHOULD BE clearly written
Oh, did you see my signature line?
Message 11 of 12
(1,004 Views)
Never forget, ModBus is based on 16 bit registers. Perhaps, if you really pass a byte value to a function in your CodeSys environment it might actually work, because it would cast it to a 16 bit value, but I wouldn't rely on that. The byte value could also land in the high byte of the register.
Message 12 of 12
(995 Views)
