Modbus libraries for LabView 8.0
I can only talk about Modbus TCP/IP. Hardware communication works fine. Slave simulation is faulty.
I modified "MB Ethernet Example Slave.vi" and simulation works fine on TCP/IP.
See attached file
Manfred
Message 11 of 81
(4,040 Views)
As you have probably realized by now, I'm not an expert in modbus. I have another question..
In the Modbus command you have some parameters called quantity and discrete, can someone explain these for me?
Btw, I think this is actually working, I just have to understand how... Smiley Happy
Thnx
Message 12 of 81
(4,013 Views)
Click on the modbus speciications button at this page.
http://www.modbus.org/tech.php
Message 13 of 81
(3,998 Views)
Need some help, again.. Smiley Happy  I'm loading measured values from my module, but when these values are negative, I get forexample 65522. Which should imply that I receive a hex number FFF2. But I want this to be represented as the negative number it is, refer to 2's complement. How can I fix this?
Thnx!
Message 14 of 81
(3,969 Views)
BTW. The received number is 16 bit binary.
Message 15 of 81
(3,967 Views)
I guess the .vi that needs modification is the: MB decode data.vi. I think I know how to convert a 16 bit number represented with 2's complement into decimal numbers, but where do I find the correct 16 bit number to translate..? And how do I convert a unsigned word of 16 bit
Message 16 of 81
(3,953 Views)
I guess the .vi that needs modification is the: MB decode data.vi. I think I know how to convert a 16 bit number represented with 2's complement into decimal numbers, but where do I find the correct 16 bit number to translate..? How do I convert a unsigned word of 16 bit integer (0 to 65535) to bits I can work with. Is it possible to convert it to signed or something, so LV understands that it's dealing with a negative number.
Message Edited by Christian_nor on 11-25-2005 07:55 AM
Message 17 of 81
(3,951 Views)
Apologies if I'm misunderstanding, but are you looking for something as shown in the attached?
Fading out. " ... J. Arthur Rank on gong."
Message 18 of 81
(3,949 Views)
Super!! I was hoping it could be that simple! Thanks alot.
rgrds.
Labview amateur..
Message 19 of 81
(3,948 Views)
Hi Christian_nor,
I have similar the same problem. Did it work in your case?
best regards
Wolfgang
Message 20 of 81
(3,898 Views)
