Modbus libraries for LabView 8.0
Yes, this is working Smiley Happy
I am using the LV 7.0 libraries provided by unclebump. (I have only tried serial communication, not tcp/ip)
-Christian
Message 21 of 81
(3,757 Views)
Dear UncleBump,
Do you mind sharing the TCP version of your Modbus VIs?
Thank you,
-Khalid
Message 22 of 81
(3,770 Views)
Manfred (and others),
Have you been able to use the TCP Modbus Slave example to write out any values succesfully?  I am able to read values into my Slave VI example, but I can't seem to be able to write values out.
Thank you,
-Khalid
Message 23 of 81
(3,760 Views)
Here is a link to a modbus ethernet query llb file. I've never used the ethernet slave vi's.
Message 24 of 81
(3,756 Views)
Modbus slave devices can only receive data. It takes a master device to write data.
Message 25 of 81
(3,756 Views)
Thank you UncleBump.  What I meant by slave writing was, when I change the values within the Slave (Coils and Registers), these do not get picked up by the Master.  This should be doable.
In any case, thank you.
-Khalid
Message 26 of 81
(3,747 Views)
Another question. I am supposed to write data to address 429 and 430. Something is not right, I am trying to write 14 to 429 and 5 to 430, 14 is correct read and the module replies. But the module is not sending any datas to 430(at least that is what the module says). See attatched figure for my configuration. Anyone?
Message 27 of 81
(3,716 Views)
There are different modbus function codes for writing single registers and multiple registers at one time. Try changing the six to the appropriate number for write multiple registers.
Message 28 of 81
(3,741 Views)
Here is a link to the modbus function codes manual.
http://www.eecs.umich.edu/~modbus/documents/PI_MBUS_300.pdf
Message 29 of 81
(3,739 Views)
Thanks, but this did not work. I changed to function code 16, which is supposed to be preset Multiple registers. See attatched configuration. Now none of the datas were accepted.
Message 30 of 81
(3,724 Views)
