Modbus serial communication
What's the actual error that occurs? What is the point of the outer while loop and the second stop button? You only need one loop.
Message 11 of 12
(1,509 Views)
Also, if you want more help with this, you might want to post it as a new topic, since this one was marked solved by the original poster, meaning fewer people are likely to read it.
Message 12 of 12
(1,508 Views)
