Model Interface Toolkit
I'm encountering an issue with the Model Interface Toolkit when trying to load more than 50 veristand models. It seems that the loading process is limited to a multiple of 26 models, typically 52, and sometimes only 26 (it can be random sometimes). The temporary reference files created in directory "%LOCALAPPDATA%\Temp" during the loading process follow a pattern like, for example:
Before I load any models, I clear these temporary files if they exist. I am not sure if it is a coincidence, but I consistently see it loads 52 models in most cases (even though more paths are available). When the loading fails, I get an error code -383200 for all subsequent models. In these tests, I used really simple models with an inport connected directly to outport.
Any direction for what should be done to get for example 100 models loaded?
I attached a simple .vi that load/unloads models.
Lukasz
Message 1 of 1
(694 Views)
