Model interface toolkit: discrete time integrator
hello,
I'm currently evaluating Model Interface Toolkit to integrate some of my Simulink model into Labview. I successfully integrated basic functions, but it failed when I wanted to integrate a model containing a "discrete time integrator" (compilation is OK but output in labview is wrong : seems that the  block doesn't  react). Do you know why ?
I was looking for documentation about block compatibility but didn't found anything.
Thanks !
(3,353 Views)
Posting what you have will help us help you.
(3,316 Views)
Attached some screenshots. Very simple model with just a discrete time integrator block. I have well configured simulink for compilation (fixed step solver and fixed time-step + infinite simulation time)
But integrator does not react, as you can see on the graph. If i change input it produces a step but definitly not the right integration output !
(3,294 Views)
