Using a browse tool in LabVIEW
Hello! would like to seek some help regarding a project that i am working on ...
my idea is to implement a function which will help me calculate a certain thermal comfort setting in a room.
the tool is known as the CBE Thermal Comfort Tool and it is free to use for everyone. The site allows you to choose temperature and it will calculate an optimized estimation of thermal comfort.
http://comfort.cbe.berkeley.edu
I want to be able to input my room temperature from LabVIEW into this website and LabVIEW will receive an output data for further calculations.
The flow goes like this
(Temp sensors > LabVIEW(receives temp) > CBE tool (uses the temp to calculate) > LabVIEW(receives output info).
can this method be done? can LabVIEW somehow extract the tool and make it workable like as if its an existing function? i am quite completely new to LabVIEW sorry about that and thank you.
(2,893 Views)
Contact the page owners and find out if there is an API for it.
(2,866 Views)
