Modify 3D curve graph
I would like to modify my 3D curve graph. What I want to do is divide the two regions of the graph area into 2 different colours. Can this be done?
Another modification I would like to perform is to replace the 3D box that the line is plotted on, and instead display a 3D representation or model of the human body, in which the line is plotted within it. Does anyone know of anyway in which this can be done?
Message Edited by bosdp001 on 06-28-2006 02:06 AM
(3,611 Views)
Do you mean you'd like to have plots on one side be one color, and plots on the other side be another color?  You'll find a number of discussion forum threads discussing 3D graphs, and there are a number of examples in the Example Finder as well.  Take a look at those resources and play with the 3D graph to get acclimated, and if you're still having problems implementing your desired functionality, repost and we'll see if we can't address some of the specific problems you're having!
Thank you,
Best Regards,
JLS
Best,
JLS
Sixclear
(3,592 Views)
Hello JLS,
I've read all these examples, but I can't find, how to plot in the 3D Curve Graph lines of different colors. In my case each line means something, and I would like to have for example one green line of width 3  and one red of width 1 one a single Graph.  I've spent already a lot of time experimenting with it
I'm  new in Labview and would appreciate any help.
(3,256 Views)
Note:
Alisia has asked the same question in the German LabVIEW forum (Crosspost) and again in the NI Forum (duplicate post)…
(3,229 Views)
