Modify Front Panel Layout and Waveforms
I have some questions about LV configuration:
1. Is it possible to modify appearance of waveforms? Colour, 3D effect, font...
2. How can i join 8 graphs into a single block. I explain, i have 8 sepparate graphs but i want to graph them into a same block but in different lines.
3. Is it possible to delete the background grid?
Regards
(4,437 Views)
1. Go into the properties of the graph.  There are a bunch of things in there for you to try.
2. You want 8 plots in the same graph?  Just build an array of the waveforms and wire it up to the graph terminal.
3. You can go into the graph properties and make the grids for each plot transparent.
(4,431 Views)
Want to do something like that.
Each colour means a graph, but all in the same block
(4,424 Views)
Perhaps you should post your code so we can see exactly where you are at.
(4,415 Views)
1. Yes, it is possible. Either before runtime or during runtime with property nodes.
2. There are a few different ways you could achieve this effect. Either stack graphs or use the mixed signal graph, although there are some caveats to using a mixed signal graph that may cause issues. A screenshot is below.
3. Yes, set the grid color to transparent.
EDIT: Ooops. I see crossrulz has already provided a solution for 1 & 3.
Corey Rotunno
(4,404 Views)
