Modify Meter Color
We've got an application taht would really benefit from the Meter or Gauge, provided we could change the color.
I've searched the forums, and while there's quite a bit on changing the color of eacharea, there's nothing on [i]adding[/i] areas or changing the [i]range[/i] of areas.
Specifically, we need the Meter (or Gauge, though Meter is prefered) to go Red-Yellow-Green-Yellow-Red, with the color change thresholds changable programatically (so the first Red could be 0-10% or 0-15%, depending on the system state).
I'm sure there's a way to do this, I just haven't figured out how.
(5,258 Views)
Accepted by topic author BobChuck
Maybe this will help.
Ben
(5,251 Views)
thats perfect, thank you
(5,244 Views)
Not only did Ben post quicker than me,
his code was a million times better than mine... so I wont even post mine to save a little of my dignity
Cory K
(5,239 Views)
Use the property Scale.MarkerValues[]. It's a cluster array where the first element is the value of the marker where the color starts and the second element is the color value.
(5,237 Views)
