Pick Point Method
I'm using the 3D picture control for my application, and I want to be able to select objects I have created, by clicking on them with the mouse.
I have tried using the  Pick Point Method of the 3D Picture control with no luck.
Has anyone managed to do this yet
(4,421 Views)
Hi Jam.hall,
I have created an example file for you which can be found at the Ni community pages.  Please see the following link:
http://decibel.ni.com/content/docs/DOC-4958
If you have any questions or if this does not solve your issue please let me know.
John
John.P | Certified LabVIEW Architect | NI Alliance Member
(4,384 Views)
That's a pretty neat example.
A few minor nitpick points: Smiley Wink
  • Use the Decrement primitive rather than a Subtract and a constant of 1.
  • The constant of 100 for the Timeout doesn't really serve any purpose. There's no code in the Timeout case, so you're forcing the code to do absolutely nothing (and loop around) every 100 msec.
  • I would place the "Name" indicator outside the case structure and if there's no hit then write out an empty string so the user knows they have not hit on anything.
(4,375 Views)
Thanks for the feedback:)
The subtract was left over from debugging, decrement is defiantly the better option!
I also agree it would make more sense to return a "No Object" message.
I have updated the example to reflect these changes.
The timeout case is actually to hide a little bug in the code 🙂
When the code first starts up two of the blocks do not appear....... and I can not work out why!  They only appear after the event structure has executed at least once so the timeout case was to force this execution.  As you rightly say there is no other purpose for it when using the event structure in this manor.
Again, thanks for the feedback 🙂
(4,368 Views)
John.P wrote:
Hi Jam.hall,
John
How do you download the example at that link?  There is a section called Downloads.  It has the name of the file followed by the word "QUEUED".  But nothing there is selectable to be able to start a download.
(4,363 Views)
I do not see this behavior. With the timeout constant removed all blocks are drawn. I'm running 8.6 in an XP virtual machine, but I don't think that would matter in this case.
(4,361 Views)
