Modify installer Process
How to add dialog box to receive inputs from user in current installer process.
(3,383 Views)
Are you referring to an installer created with a LabVIEW build specification? If so - it isn't possible to modify. You would need to either:
- Look at using an alternative installer (e.g. InnoSetup) which has more customisation options
- Create a small LabVIEW executable that has your 'dialog' and call that as the 'run this executable after the installation' option of the installer build spec. This might not work if the runtime engine requires a reboot before your executable will run.
(blog)
(3,349 Views)
