speed control of shunt motor using labview interfaced with arduino
I'm trying to control the speed of a shunt motor using LabView with PID interfaced with Arduino which is connected to the tachogenerator sensor of the motor anyone offer any advice  I have a voltage divider for the sensor to Arduino as is max out is 5v and the sensor is 2v/1000rpm. the motor is being powered by a three phase power panel and a thyristor panel
(3,354 Views)
Very pretty picture, showing "real wires".  Do the orange ones have double-precision voltages, and the green ones TTL Boolean signals?
You didn't ask any question, and didn't provide any code (no pictures, please, just the VIs) for us to examine.  I hope it is all working for you ...
Bob Schor
(3,342 Views)
Hi Bob there are no orange wires, the green are small voltage wires, thank you. The three phase and thyristor panel with a rectifying circuit (green cables) run the motor (150v DC 300w 300rpm) with a speed dial connecting to the firing circuit on the thyristor panel.
what I want to ask is how can i go about connecting the tachogenerator sensor, I made a 2 wired cable connected to the motor and the speed dial into arduino, will I need code if I'm using LabVIEW ? Is a voltage divider enough ? sadly I have had to start again my laptop crashed last week now I have a slow one which is having problems updating the drivers for arduino. I'll upload the VI soon as I can. I am knew to this so any help will be much appritiated
(3,307 Views)
here is the vi that i`m trying to use
(3,277 Views)
