Modifying a particular line (content) of data in a file.
Hi All,
I've a requirement with file modifications, but i'm new to Labview so couldnt correctly fix it...
My req is something like this.....
I've a file named mytemplate1.txt which is added to this post....
In that i've a line, i.e no. in attacehd is 153
"modelLanguageCode=ENU"
In that i wanna put a control to the bolded one above.
So whenever i modify that control to SPA, GER, JPJ .....
It should update the content respectively.
I tried with different file functions available in Labview 8.2 but unable to find the solution ...
So my temporary approach for this is
Concatenate string
where
Part 1 is data above modelLanguageCode=
part 2 ENU
part 3 data after "modelLanguageCode=ENU"
But this doesnt looks ideal for my req.
So please suggest any good solution....
-Suneel.
(2,634 Views)
Have a look at the attached example.
Craig
Message Edited by craigc on 07-15-2008 03:50 AM
Message Edited by craigc on 07-15-2008 03:51 AM
LabVIEW 2012
(2,628 Views)
Hi Craig,
Thnaks for ur help....
But its is again appending the mytemplate1.txt
anyways i will try to write it to a new file....
-Suneel
(2,608 Views)
Yep my fault,
In between the file read and the file write operations.  set the file position back to 0 using "set file position.vi" under the advanced sub pallette within the file pallette.  I have verified this works correctly.
Craig
LabVIEW 2012
(2,600 Views)
Vow Craig,
That's really helpfull thanks....
Thanks again....
-Suneel
(2,589 Views)
