Module based design
Hi
We have made a report generator using the LabView object structure. The ancestor object talks to the printer and childs produce report content. This makes us able to add/change reports without breaking other functionallity in the code.
Now I would like to separate reporting from the rest of the code. The aims are to work on multiple parts of the code simultainiusly and to reuse code.
Where should I start looking?
Could libraries be usefull in this case?
(4,259 Views)
I'm not sure what you mean by "seperate reporting from the rest of the code".  Trying to make these a reuse library?  Trying to make a reporting module that other parts of code use some communications scheme to send data to?
(4,254 Views)
Your option "reuse library" sounds good. We have 1 ancestor and about 10 child objects that generates different report types.
(4,231 Views)
Accepted by havard@wide.no
I always put my class structures in libraries because I get better access control.
I also hide the subclasses from the calling application and create a layer of interface VIs in the top-level parent class.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,214 Views)
Thanks!
Youy write "hide the subclasses from the calling application" . What do you mean?
(4,187 Views)
I set the Access Scope of all the subclasses to private so the only access calling applications have is through the dynamic dispatch interface VIs in the top-level parent class.
Mike...
LabVIEW Champion
(4,174 Views)
I also recommend you learn to use VI Package Manager.  It makes sharing your reuse a lot easier.
(4,149 Views)
