Monitor computer power events
Is there a way to monitor if a computer shuts down, restarts, hibernates, sleeps or logs off?
I need to do something if either of these events occur.
If this is possible, please tell me how to do this, and if you could give me some code I will appreciate it.
Thanks.
(3,752 Views)
searching for LabVIEW Help
Here's an example.
The System Exec.vi is located on the Functions Palette under Connectivity >> Libraries & Executables.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(3,705 Views)
correction just type "shutdown -s" in command line
syrpimp
(3,692 Views)
That causes a shutdown.  The OP is looking for a way to check if the computer is shutting down.
(3,684 Views)
The following link may help you:
Ending LabVIEW Program Before Windows Shuts Down:
http://digital.ni.com/public.nsf/allkb/66659ACE17C686418625736000606A64?OpenDocument
David P.
Applications Engineer
www.ni.com/soporte
(3,634 Views)
