Monitor shared variables like an OPC client?
I would like to build an OPC client in LabVIEW 8.01. This is what I have done:
- Added several shared variables (binded to TAGs in an OPC server)
- If I drag drag the shared variables to the front/block panel/diagram, I can monitor which variable I want
Is it possible to create a list of all shared variables, and monitor the values?
(I know that you can open "Monitor Variables..." under Tools --> DCS Module. There you can select which variable you want to monitor.)
Like I said, I would like to create an OPC client that monitors all the shared variables
regards
Richard
Message 1 of 1
(2,325 Views)
