 rifo
			rifo
			05-24-2011 01:16 PM
I am trying to build a program to monitor 2 wind turbine and a meteorology station. All of them have their own software; and they give continuously real time data in text format. First Wind Turbine (WT) has a software which is designed also by labview but I can't see the codes. The time format of it is here:For 2011:03:02:10:49:42,390. I have seen this format in Format Specifies Syntax. The other WT' time format is here:2011 03 08 00 00 29 6. And the meteorology station has this format: 08.01.1114:14. (I upload text file examples)
My goal is to graph data's in other columns according to time. But each text time has different time format. Should I make them time string in same format then use them in graphs? I was not able to build a VI which recognize 2011:03:02:10:49:42,390 and graph it with RPM (for example).
Thanks a lot for any help.
Regards
05-24-2011 01:40 PM
sorry, I have posted 2 times because of connection problem. Please, feel free to delete this post!
thanks
 altenbach
			altenbach
			05-24-2011 01:40 PM
