Month Calendar
when i try to put MonthCalendar on my VI with Labview 8  compere a dialog box with this message:
you must upgrade your .net framework 1.1 to Service pack 1or later use
i,ve just installed on my pc .NET Framework 1.1
how i can solve this problem to use .NET function ?
thanks
gianni
(3,874 Views)
You can get service packs from Microsoft. One way is to use Windows Update. Open IE and under the tools menu select Windows Update. Once that has started ude the Custom button to get a list of updates. The dot net update should be there.
(3,869 Views)
Hi giannilio,
Just as Odd-Modem said.........After the .NET update just place the .NET calendar control in your vi front pannel, it works.
Here is mein.
Ohiofudu
Certified LabVIEW Architect
Certified TestStand Architect
(3,849 Views)
it dosen't work!!
i've already installed Windows 2000 with service packs 4
in ActiveX calendar control  it works , but i must solve my problems as soon as because i need work with .NET function
thank you
(3,840 Views)
http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displa...
That's what you need, not a Windows service pack.  Install that service pack for .NET and everything should work fine.
(3,828 Views)
