I built menus using the "Menu" blocks.
I was wondering if there is a way to have certain menu items highlted grey (not selectable), until operator select another menu & answer fill in the info in it.
I'm attaching the Menu Selection module I did ( I know other modules well come in as bad), but well give you idea what I'm talking about.
When the program runs, "Mode Select" menu runs first, then I would like to force the operator to select "0-Span" next (have rest of menus highlted grey, except the "Inspection End") This is not the only one depandant.
Once "0-Span" is done, then they can select "YM Assgin" but not the rest of the menu, after that they can select "Sample Set1", but "Sample Set2&3" are heighlted grey until Sample Set 1 is selected. You can see what I'm aiming for is to have certain items on menu depandant on other before allowing its selection.
Thank you.
