Most efficient way to extract the amplitude of a signal and display on an intensity graph
Hi All,
I am having difficulty to display the amplitude of an voltage signal (voltage picked up by NI DAQ card).
what I am trying: Voltage signal (Dynamic data type)--> 2D array of dynamic data type (using 2 nested for loops) --> normal 2D array with scalar values --> intensity graph
I have difficulty to convert the dynamic 2D array to scalar 2D arry.
I only want to extract the amplitude of the imcoming signal.. any body can give some advice? thanks in advance..
Charlie
(3,933 Views)
Hi Charlie,
Have you tried using the Amplitude and Levels Express vi? It is located in the Functions Palette»Programming»Analog Waveform»Waveform Measurements»Amp & Level.
Hillary E
(3,909 Views)
Hi Hillary,
Thanks for your reply. 🙂
Yes, I did tried to use Amplitude and Levels Express vi, it should be the one I am looking for, but I found it not work in my case, I need to put the value of amplitudes into a 2D array.
If I use
Amplitude and Levels Express vi, it will give me a 3D array, I have found the solution, just convert the dynamic data to single scalar. (see pic attached)
Anybody can help me to solve the following 2 problems:
1. The speed of this program is too low, i think ii due to the DAQ assistant in the 2 for loops (for creating 2D array), it should be able to re-write using DAQmx (as "centerbolt" told me), I am working on this now, if anybody can help, I will appreciate that.
2. Is there any other way to creat the 2D array (for purpose of increasing speed also).
Charlie
(3,892 Views)
Hi Charlie,
1. You can create the DAQmx code from your DAQ Assistant by right clicking on the DAQ Assistant and select Generate NI-DAQmx Code. You might still need to modify some of the to your exact application. (You might find context help (Ctrl+H) useful.)
2. You can also create arrays using the Array Palette (in the Functions»Programming Palette). There is a lot in LabVIEW help as well (Help»Search the LabVIEW Help...»Index Tab» array or arrays. You might to particularly look at "arrays, inserting elements programmatically".
Hillary E
(3,874 Views)
