Motion detection using webcam
Im fairly new to labview & got a university project related to the subject.
The basic outline of the project is to:
Use a webcam to detect motion
After the motion is detected, a motor connected underneath the webcam should turn on and follow the moving object(i.e it should rotate left if the object goes left and so on)
What i plan to do is first of all work on detecting motion only.
Im attaching the block diagram & VI of what i hv done uptil now.Right now as soon as the VI starts, the webcam takes a still image and stores it, and at the same time keeps grabbing live video stream.
Now, i want to subtract these two images and give the output to an LED which will turn On everytime it detects a motion, but i dont know how will i be able to do this. I cant understand how to get a simple true/false output from the subtract option.
Please advice.
Aamer
(5,233 Views)
First piece of advice is to search the forum.  There have been lots of discussions about webcams here before.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(5,203 Views)
Hi Aamer:
Like Matt said, I would spend some time searching the forums for some other methods for motion detection.  Instead of the subtract function, I think you'll be better off doing some object detection and then do you tracking on it.
Also, just a general programming tip, it does no good to have your subtract function outside of your while loop like it currently is.  No images will come out and go to the subtract function until you stop the while loop.  Even then, you will only get one image.
Alex Person
NI-RIO Product Support Engineer
(5,174 Views)
