Mouse click or enter
I have an application that contains multiple event structures that use a mouse click to exit the event. Is there a simple way to set the event structure to recognize either a mouse click or an enter keystroke as a valid trigger?
(394 Views)
Once you give a bit more explanations, we can probably help.
  • What is your definition of "exit the event"? What triggers the event? A typical even should complete on its own quickly? Are you talking about an events in an event structure or something else?
  • how many are "multiple event structures"? What do they do and why?
  • What kind of mouse-click? (click on a control or indicator? Click on the panel? Right? Left? How do you distinguish from other mouse actions? etc.)
  • What kind of key stroke? (any specific key? key navigation, etc.)
  • What is the overall program architecture?
Can you attach a simplified example?
(362 Views)
There have been multiple posts in the LabVIEW Forums that come from New Members (such as yourself) to start with a question so strange that it appears to be a "phishing" attempt.  Posts, such as yours, seem to show little knowledge of LabVIEW (see Altenbach's questions) and no evidence that you've looked at the Forum and seen that many posters asking for help show relevant code (best being VIs saved "for previous versions" specifying LabVIEW 2021) so even if you don't really know what you are talking about, we can see what you are trying to do (like why you talk about "multiple event structures", instead of an Event Loop handling multiple events).
Looking forward to learning more about you and your LabVIEW questions after you reply to Altenbach.
(329 Views)
Sorry for the delay. My replies kept getting bounced back
Fair questions. I assumed it would be an easy one to answer.
It is an event structure that is satisfied when the OK button changes value. This is currently accomplished via a mouse click of the displayed OK button.
I use this same code, passing different items, throughout the application. That is what I meant by multiple event structures. It's actually the same structure used many times.
My goal is to recognize either the OK button change or the Enter key as valid exit criteria.
I can't attach the sample code with my Kindle
Thanks, Rex
Thanks, Rex
(246 Views)
@oldman53 wrote:
It is an event structure that is satisfied when the OK button changes value. This is currently accomplished via a mouse click of the displayed OK button.I use this same code, passing different items, throughout the application. That is what I meant by multiple event structures. It's actually the same structure used many times.
To detect a value change of a button, I assume you are using a "value change" event (not a "mouse down" event). You can have it to also react to the enter key by defining key navigation. That will trigger the value change event too.
What is the mechanical action of the button?
(230 Views)
Seconding this recommendation- instead of having the Event structure respond to the Enter keypress, set the button to respond to the Enter keypress. Right click on the button to set that up.
(181 Views)
