Mouse down on 3D picture control
i would like to know how to indicate mouse down on the 3D picture control as can be done for the picture function.
regards
king1
(3,420 Views)
Hi King1
I  am currently working on this issue and will be in contact with some information when I have something.
Thanks for your patience
Best regards
Rob L
Rob L
NI Applications Engineer
UK & Ireland
It only takes a click to rate this message 😉
(3,401 Views)
Hi King1
I have been able to modify an example VI which came with LabVIEW v8.2 which uses the 3d picture control. I have added an event structure to the code which allows the user to pause the rotation of 2 objects in the picture display area. I have added notes to the block diagram which should help in describing its behaviour. the file is attached with this post.
I hope this is of some help, there are a few more 3d picture examples in the LabVIEW example directory which might also be of use.
Best wishes
Rob L
Rob L
UK & Ireland
(3,387 Views)
Hello dear colleagues
Would you be so kind to share code example for mouse down (and not only zooming) and programmatically action for this mouse down.
For example I have multiple cones (in my case their 90 pieces). So that I'm left-clicking on any of the 90 cones then I can increase (or do some other action with the selected object) this cone or other object selected by the mouse
(2,013 Views)
