how to solve error -61499?
When compiling FPGA vi, I encountered the following errors: Error -61499 occurred in: niFpgaCompileWorker_AnalyzeTimingViolations.vi<-niFpgaCompileWorker_AnalyzeTimingPaths.vi<-niFpgaCompileWorker_CheckForErrors.vi<-niFpgaCompileWorker_JobComplete.vi<-niFpgaCompile_Worker.vi:1 Additional information:Traceback (most recent call last): File"./objects/lvfpga_dist/win32U/i386/msvc90/chn/root\resource\RVI\TimingViolation\scripts\niFpgaTimingViolationMain.py", line 280, in NameError: name 'constraintDict' is not defined Why this error come out?how to solve it?
(3,883 Views)
Found this post with similar error as yours.
Hope the solution is able to help you:
https://forums.ni.com/t5/LabVIEW/LabVIEW-FPGA-Module-internal-software-error-61499/td-p/3107596?prof...
(3,860 Views)
你好,请问您的问题解决了吗?我也遇到这样的问题了。
(2,832 Views)
