Move Labview runtime
i have an application labview runtime running under Windows 7 in Computer  "A",  but next 2024 our IT Dept will replace it ,
so next 2024 i will have a New Computer running Win10 , and i need to move the application to the new one,
see picture attached NI MAx Summary Sotware
i need to know the steps to move my current application to another new computer including all toolkits
Note : the app was developed by a external contractor
(1,375 Views)
According to Running Executables or Installers on Different Windows Versions
Installers and executables are only guaranteed to work on the operating system they are built on.  For example, a Windows 10 installer or executable may not work as expected on a different Windows version (e.g. Windows XP, Windows 8, or Windows 7).
You should reach out to your contractor for the source code or ask them to build an installer for Win10. What Are the Differences Between a LabVIEW Executable and an Installer
https://tmesystems.net/
(1,370 Views)
The most common installer setting is "Windows 7 or later", so if you have a good installer package it should just be to install and be happy. Some are less complete and you might need to download and install e.g. DAQmx yourself. It's usually not any big problems.
Qestit Systems
Certified-LabVIEW-Developer
(1,274 Views)
