Move graph palette programmatically
@mcduff wrote:
I use the same method myself, and given a kudo to your idea in the past. (When I clicked a kudo disappeared then when a re-clicked it came back.)
Hah, so you have! Re-kudoing it doesn't up the number any but it does give that little dopamine hit of "ooh, a kudo!" since it re-sends the notification 🙂
Message 11 of 16
(1,623 Views)
@paul_cardinale wrote:
wiebe@CARYA wrote:
@TenJigoku77 wrote:
There is only 1 solution for me but it takes time --> Replacing the palette with a new control wich does the exact same things that the palette and then resize it.
Sadly, that is the only solution I've found.
There are ways to get a reference to the graph palette, but I wouldn't use them in production code.
Really?  What are those ways?
Pretty sure you've posted one: Guess the UID's; Convert to reference...
Message 12 of 16
(1,613 Views)
@daveTW  a écrit :
Another note: Set the min-size of the pane to a value where the graph palette always does as expected
Hey everyone,
Thanks for all your propositions.
Somehow I feel relieve that I'm not the only one getting issues with that.
daveTW, it's a simple solution but I think I will go with that, after testing it of course. I didn't think about accessing pane properties to fix the min size ^^
Thanks BertMcMahan for the info, I'll try this aswell, even if it's quite odd to handle 2 panes that should have been on the same one. And in my case each pane have a specific thread so it means having to handle another thread 😫
I'll keep you posted with that.
By the way, is it possible to accept 2 message as a solution ?
Bye !
Message 13 of 16
(1,595 Views)
It took me a while to find it (https://forums.ni.com/t5/LabVIEW/How-to-get-a-variant-s-value-as-a-string/m-p/4197740#M1215137).  But it doesn't find the Graph Palette (despite the fact that the Graph Palette is a decoration owned by the Graph.
Message 14 of 16
(1,584 Views)
Not sure why that loop wouldn't catch that UID.
UID To Reference does seem to crash LV quite a lot when tried with random (invalid) UIDs.
However, I used this to get the graph palette's UID:
Simply make sure there's no selection, then run this VI and select the palette (while subject isn't running).
After that, I can move the palette with that UID (..\LabVIEW 2020\vi.lib\VIServer\UID to GObject Reference.vi).
For the rest of the group, the UID won't change unless the graph is deleted.
Message 15 of 16
(1,533 Views)
I figured out what's happening:  The loop stops when it gets to a UID of an object that isn't owned by the graph.  Apparently the Graph Palette isn't created until it is made visible.  As a result of that, the objects owned by the graph don't have contiguous UIDs.
Message 16 of 16
(1,524 Views)
