Move.vi error10.
I checked the posts but couldn't find anything that explained my particular situation.
I am trying to rename a file by changing the extension from .tmp to .txt
That's it!
It is creating the new file (.txt), but not deleting the old (.tmp).  I also attached an image of the error message.
What am I missing other than my sanity?
(4,494 Views)
Hi epster88,
did you check both path using probes or indicators?
For safety you should always use file functions to manipulate filenames (strip path/build path/GetFileExtension)...
Message Edited by GerdW on 09-03-2009 09:43 PM
(4,484 Views)
Accepted by epster88
The second path should be a directory if you're trying to move.
Apologies... The only issues I see with this is, that either the file already exists, or there is write permission error..
Message Edited by NitinD on 04-09-2009 01:17 AM
(4,482 Views)
Hi NitinD,
no, the target path can include a filename, this example works fine for me:
(4,471 Views)
My bad... guess i'm sleepy... I tried running it... it works fine in my computer...
By it I meant the code in OP
Its working on my system for a hard disk path...
Message Edited by NitinD on 04-09-2009 01:27 AM
(4,467 Views)
That's it.  I forgot that this account could only write to the directory, not delete or edit.
Thanks NitinD
(4,450 Views)
