Movement, Measurement and time between them
Hello friends,
I have a doubt with my program. I've made a statemachine (using Lab 9.0, no possible to use a new one) to move two motors and make a measurement (IV curve). Motors move and measurement is done, however this measurement is made meanwhile motors are moving, why?
What should I do? I want the motors move, then make the measurement, when this is made, then move motors again and so on.
Any idea? All help is appreciated. Smiley Wink
Attached you can find the program (sorry because of the drivers, they are Thorlabs for motors and Keithley 2400 for Measurement)
Message 1 of 14
(5,162 Views)
No attachment.
My initial thought is that you need to add a wait after moving the motors to allow the system to actually respond before you take the measurements.  Hard to say for sure until we see some actual code.
Message 2 of 14
(5,159 Views)
You´re right Crossrulz, I forgot to attached the code, sorry!! Smiley Embarassed
Here you´ve got it! I´ll wait for your answer!!
Message 3 of 14
(5,132 Views)
Hi lacorgui,
you need to wait for your motor(s) to reach it's postion. Right now you just send a command to the motor(s) but you don't wait for them to finish movement…
Setting a callback is not the same as waiting for finished movement!
Message 4 of 14
(5,128 Views)
Hi GerdW,
I added the callback as a possibility but I do not know exactly what expect from it. I understand that I have to wait for the motor to reach its position, but how could I make this?
Message 5 of 14
(5,123 Views)
Hi lacorgui,
well: don't change the state until it reaches it's desired position…
Message 6 of 14
(5,120 Views)
I see.
The thing is that if I run the program with the "light" (like in a probe mode) it works fine: first move, then measure once motor is stopped.
However, if I run the program directly measure is taken while motor is moving to next position. I will need the program to make thousand of measurements in a sample for long periods of time so I have to be sure that the motor stops and then measures.
My question is your point: how can I tell the program to wait in the state until it reaches the position?
(Thanks for your help)
Message 7 of 14
(5,117 Views)
Hi lacorgui,
you set a new position and you read the current position.
What about a simple comparison if "current postion" is (nearly) equal to "set position" and changing the state based on that comparison?
That's how a state machine works: you have some rules to decide which state to go…
Message 8 of 14
(5,111 Views)
Ok, I´ll try that. Smiley Wink
Message 9 of 14
(5,109 Views)
lacorgui wrote:  The thing is that if I run the program with the "light" (like in a probe mode) it works fine: first move, then measure once motor is stopped.
That is called Highlight Execution.  Things with instruments tend to work so much better with Highlight Execution turned on purely because it slows your code down to a crawl.  This just screams the need to add in waits.  The state machine approach is the better way to go.
Message 10 of 14
(5,082 Views)
