Problem with Automatic Gain Control Example
I tried to open AGC example here, i'm using labview 2013 and installed DSP module 8.6 but it didn't work.
The project give warning at DSK6416,DSK6711,DSK6713 and speedy-33 and the VIs AGC, EMB sinewave form can't be found.
I tried to install Speedy-33 driver separetly but it said that a later version is already installed.
(3,604 Views)
Unfortunately, teh DSP module is discontinued. There is no DSP Module available for LabVIEW 2009 or later. The version you have will only work for LabVIEW 8.6 or 8.6.1.
This is another post with the same problem just for reference.
http://forums.ni.com/t5/LabVIEW-Embedded/DSP-Module-For-LabVIEW-2011/td-p/1956523
Camilo V.
(3,551 Views)
