Read TDMS - Calculate Average
I acquired data which I stored in a TDMS file and I'd like to make some calculations such as find the mean of my data set.
I successfully read the TDMS file and linked it to a waveform graph, no problem on this part.
However I'm stuck when trying to understand how can I get access to the data other than just to print them on a graph.
How could I sum all the values to find the mean value ?
I'm using LabVIEW 2010.
Thank you.
(4,430 Views)
Accepted by topic author Vinc_sp
Use the Mean.vi function under the probability and statistics.  I'm guessing you are reading a waveform and may need to pull out the Y values using the Get Waveform Components function.  Post some code if you are stuck.
(4,428 Views)
Well, thanks I made a big step. However the result returned is 0.00.
What am I missing ?
I've attached my code and a pic of the waveform.
(4,416 Views)
No need to pull out the Y.  There is a Waveform DC/RMS measurement VI that will do the job.
(4,408 Views)
Based on the data, that is perfectly reasonable.  Try changing your display option for the indicator to Exponential or SI notation and you should see more digits of precision.
(4,405 Views)
Thank to you too !
My 0.00 problem was solved actually I don't really know how. It was a matter of values after the decimal. I just created a new dbl numeric constant which I changed into an indicator.
I attach my code in case someone face the same problem.
(4,401 Views)
