Moving Modal Panels without Title Bars
We have custom modal dialog boxes without Title Bars that we want to be able to move around the display by dragging and dropping in the usual way but by left clicking on the panel background rather than the title bar.
Programmatically I appear to have to re-position the front panel and all of the display/control elements on that panel fo every move step, is this right or is there an easier way?
Does anyone have any thoughts?
Regards
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
Message 1 of 8
(4,611 Views)
hi there
see attachment....
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 2 of 8
(4,608 Views)
whoa...
you have to use right click in my vi... switch to "Button 1" in the diagram for left click movement.......
Best regards
chris
Message 3 of 8
(4,605 Views)
Nice.
Cheers
Steve
Message 4 of 8
(4,600 Views)
OK that looks nice, but I have one problem what if i move my mouse off the panel then there will be no more events, does anyone have an idea to track the mouse outside the VI?
Ton
My LabVIEW Ideas
Message 5 of 8
(4,564 Views)
Remove the Event Structure?
Regards
Steve
Message 6 of 8
(4,546 Views)
try this....
Best regards
chris
Message 7 of 8
(4,544 Views)
Hi Chris,
you're answer came close, I modified it a bit to be more accurate. The things I've done are:
move the location reading into the event structure (it's better correlated, in the time-out you had a lag of 10 ms.)
set the timeout to -1 when the mouse is inside the pane (mouse-enter and mouse-leave events)
Then I'd thought wouldn't it be nice if this code can be a sub-vi called on a mouse-down event?
That worked BUT in the subvi there are no events generated on the pane class, althought dynamic registration worked I can't seem to trigger events... Smiley Sad
So the sub-vi works but only because of the time-out case....
Sorry but i can't add attachments
Ton
My LabVIEW Ideas
Message 8 of 8
(4,516 Views)
