Moving average of 2d array.
Hii Friends,
Can anyone help me to go through this problem.
I have a task wherein, i need to implement the following steps.
1) Open a existing spreadsheet file( consisting of p and s columns)
2) Remove peaks of s column by selecting a certain value and then removing the corresponding p column values.
3) I then need to take the moving average of both the p and s columns with interval 10. By this i mean, if i have the following points say
x      avg(x) with interval 10
1       N/A
2       N/A
3       N/A
4       N/A
5       N/A
6       N/A
7       N/A
8       N/A
9       N/A
10    (average of 1 to 10) = 5.5
11    (average of 2 to 11) = 6.5
12    (average of 3 to 12) =  7.5
I have been able to complete the first two steps
I have seen examples of 1d array moving averagin. Since the array is a 2d one, i am slightly confused on how to take the moving average of both the columns at once.
can anyone suggest me a way forward.
Attaching the excel and the VI.
Thanking you.
Pa1
(6,129 Views)
If you need to take the Moving average of P and S Columns Separately, Index this columns into two 1D array and do a running average by taking the array subset where the offset should start from 0 to N and the Length remains same Assume 10
Hope this will help you!
(6,083 Views)
Thanks PalaniveIT for your reply.. can you show me a screenshot of how to index the columns into 2 different arrays..
(6,081 Views)
I gave a try..is it the right way to do array indexing?
(6,071 Views)
Accepted by Pa1_korea
If you are acquiring data continuously instead of Loop can be eliminated the indexing can be Maintained in Acquiring Loop or using shift register
(6,070 Views)
HI,
a solution based on ready-to-use functions in LabVIEW:
(6,058 Views)
