Moving to the next row/column in ListBox with enter/tab?
I have a ListBox, into which I load multi-column, multi-row excel files. Once I select a single cell to motify it, I would like to move down to the next row or left/right to the next column with enter and tab keys respectively? It would be especially nice to be able to move to the next cell with it being active, so that I can make changes without touching mouse pointer.
Is it possible to do?
(5,174 Views)
The problem with editing a listbox at runtime is that the contents you see on the front panel isn't data -- its a property of the control. A table control however can be modified at runtime and it already has some navigation built. Tab moves to the next cell. Ctrl left and right arrows move back and forth whole cells. Return moves down a line. Etc...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,150 Views)
Is this what you want?
(5,123 Views)
Could you reupload version for 2014 LabVIEW? Thanks
(5,108 Views)
Accepted by armendzh
(5,092 Views)
Thank you! Exactly what I been looking for.
(5,080 Views)
