Moving to the next row/column in ListBox with enter/tab?
I have a ListBox, into which I load multi-column, multi-row excel files. Once I select a single cell to motify it, I would like to move down to the next row or left/right to the next column with enter and tab keys respectively? It would be especially nice to be able to move to the next cell with it being active, so that I can make changes without touching mouse pointer.
Is it possible to do?
(5,272 Views)
The problem with editing a listbox at runtime is that the contents you see on the front panel isn't data -- its a property of the control. A table control however can be modified at runtime and it already has some navigation built. Tab moves to the next cell. Ctrl left and right arrows move back and forth whole cells. Return moves down a line. Etc...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,248 Views)
Is this what you want?
(5,221 Views)
Could you reupload version for 2014 LabVIEW? Thanks
(5,206 Views)
Accepted by topic author armendzh
(5,190 Views)
Thank you! Exactly what I been looking for.
(5,178 Views)
