Mr. Altenbach or someone! Can you please show me a demonstration of how this code works? (attached VI would be better)
FYI: This code is Mr. Altenbach's code from an old post. This code is used to search 2D array.
So when running the code, I typed Apple. I kept getting "not found".
Note: Please if you attach a VI, save it for previous labview version. Otherwise, I will not be able to open it.
Also please feel free to share a different code that works. I am also working on this.
Message 1 of 12
(2,039 Views)
Try typing A instead of Apple.
What- no Elderberries???
-AK2DM
Message 2 of 12
(2,035 Views)
1: the code searches for "A", not "Apple". It returns "Apple" when you type "A".
2: if saving for a previous version, it would help to know which one.
_______________________________________________________________
"Computers are useless. They can only give you answers." - Pablo Picasso
Message 3 of 12
(2,025 Views)
I tried typing A, a, "A", "a". I kept getting <not found>. Did it work for you?
Never mind. I figured it out.
Thanks for your help!
Message 4 of 12
(2,018 Views)
Yes, I did type A, a, "A" or "a". I kept getting <not found>. Did it work for you? I am using LabView 2019.
Never mind! I figured it out. Thank you for your help.
Message 5 of 12
(2,017 Views)
What did you figure out? Be kind to future people who find this post and let us know what you needed to do.
Message 6 of 12
(1,994 Views)
Accepted by GRCK5000
Glad you figured it out.
Yes, since I wrote the code, it obviously works! All my code works! Always! If it does not work, it is a PEBKAC problem outside my control. 😄
It is really bad form and very impolite to attach code that has already been posted and is not yours, especially if you re-save it maximized to the monitor for some crazy reason! Next time just give us the link to the old discussion!
Message 7 of 12
(1,990 Views)
Note that the originally posted Vi had a poor default value for the string control. I attached a new version in the old thread. (Note that this was not my mistake, but originated from the VI of the OP)
Message 8 of 12
(1,940 Views)
@altenbach wrote:
 I attached a new version in the old thread ....
And what super powers do you have that enable you to edit a 5 year old post? I cannot edit any of my post after about 5 minutes (or some other arbitrarily short timeframe)
Former Certified LabVIEW Developer (CLD)
Message 9 of 12
(1,886 Views)
Mr. Altenbach is the man! hahah
Message 10 of 12
(1,879 Views)
