Mr. Knutson, how can I change the slot # on my channel vi (probably through a conditional statement) when I reach the half-way mark in the 40th iteration of a 80 iteration for loop.
I am using the external multimeter and the mux as you have suggested with the channel vi. It works great for the 40 channels on the first mux module, but I have two. I need to access the second slot automatically once the first slot's channels have been measured. I have tried boolean comparisons and case structures but they won't work properly for me. Any guidance you could give would be greatly appreciated.
Baird
(2,685 Views)
If you compare the iteration to greater than or equal to 40 and place the slot number inside of a case statement (False = 1, True = 2), it should work.
(2,685 Views)
Mr Knutson,
This answer is exactly what I was looking for. However, I discovered how to do this before you had a chance to respond. I did it exactly the way that you described it.
Thanks again, I may be calling on your expertise in the future no doubt.
Baird
(2,685 Views)
