Multi Channel Data Acquisition using PXI-6143
Morover the physical channel is set to "PXI1Slot2/ai0", instead of "PXI1Slot2/ai0:1"
Marco
Message 11 of 19
(1,326 Views)
Sorry my expranation is not enough.
I want to display the signals of ai0 and ai1 on different graph at same time.
And later, I want the two signal to trigger and acquire.
Message 12 of 19
(1,315 Views)
Message 13 of 19
(1,311 Views)
Your explanation was enough. You've been told what you did incorrectly. Please make the corrections and repost if necessary.
Message 14 of 19
(1,310 Views)
I want to multi-channel DAQ with analog triggering.
As the previous step, I had been able to acquire one channel data, trigger to one channel data.
So as the next step, I want to acquire two channel data at the same time.
The attached code can sample two physical channel at the same time and display on same graph.
But I think it is necessary to separately get the two data for triggering.
How can I get two sampled data separately?
Message 15 of 19
(1,304 Views)
Your board only supports digital triggering.
In order to separate the data into channels, you just use the Index Array function.
Message 16 of 19
(1,301 Views)
Hi Dennis_Knutson!
Thank you for the advice.
Using Index Array VI, I could acquire and save two sampled data separately (as attached code).
I think multi-channel DAQ with analog triggering is realized by connecting the wire from Index Array to analog triggering SubVI.
The SubVI for one-channel data I had alread made.
I will try it.
Thank you very much!
SHOTA
Message 17 of 19
(1,284 Views)
Dear Dennis_Knutson!
I have a trouble about multi channel DAQ treated in this thread and posted the new thread(http://forums.ni.com/t5/LabVIEW/Multi-Channel-Data-Acquisition-using-PXI-6143/m-p/2675463).
I'm glad if you give advices.
Message 18 of 19
(1,249 Views)
Dear MarcoMauri!
Message 19 of 19
(1,247 Views)
