Multi condition looping
Also I have questions, I hav eto mimic the RMC program in labview the expression command is not possible in labview.
Also how to acess the status bits from rmc and how to convert real to DINT.? If we use sine wave start command of RMC how can I show in the labview program the plot.
how to use jump command or link command of rmc in labview?
Message 11 of 13
(665 Views)
Hi
I see that in each case, you have one vi which is called 5 times. instead, you could put the vi inside a For loop, set N to 5 and wire the (i+1) terminal value to the input where you have wired 1,2,3..
then, move all your block diagram objects close enough so that the entier BD is in one screen. make it compact
Regards
Freelance_LV
TestAutomation Consultant
Message 12 of 13
(664 Views)
thats the flow
Message 13 of 13
(663 Views)
