image color legend
Hello
I have image with custom pallete:
I want to create legend that value 1represented by red 2 by blue and so on like in graphs or charts.
Any ideas??
(2,638 Views)
Hi!
 There is no inbuilt function thad does this, so you'll have to create a custom control to display the required information.  I've made a little example VI that does this, I hope I understood your goal correctly. In the example, I assumed that your color palette information is stored in an array of RGB values, and that you want cusom (preset) names for the channels.
Kind regards:
Andrew Valko
Andrew Valko
National Instruments Hungary
(2,609 Views)
Can You save this as 2011 version??
(2,607 Views)
Accepted by topic author pawhan11
Sure thing, here you go.
Andrew Valko
(2,605 Views)
