image color legend
Hello
I have image with custom pallete:
I want to create legend that value 1represented by red 2 by blue and so on like in graphs or charts.
Any ideas??
(2,646 Views)
Hi!
 There is no inbuilt function thad does this, so you'll have to create a custom control to display the required information.  I've made a little example VI that does this, I hope I understood your goal correctly. In the example, I assumed that your color palette information is stored in an array of RGB values, and that you want cusom (preset) names for the channels.
Kind regards:
Andrew Valko
Andrew Valko
National Instruments Hungary
(2,617 Views)
Can You save this as 2011 version??
(2,615 Views)
Accepted by pawhan11
Sure thing, here you go.
Andrew Valko
(2,613 Views)
