Multicolumn listbox, jump 1 cell down
In a multicolumn listbox I want do be able to enter numbers in column 2 (ringnumber as header)
After entering a  number I want to jump 1 cell down by pressing either "ENTER" or "TAB".
See attached picture.
Can anybody help me?
(3,888 Views)
Accepted by mkoppelgaard
You can do that using key events on the control to capture the key strokes.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,851 Views)
Made this, which works fine, when I press the TAB key.
Would like to catch the Enter button, but the  the scan code event does not catch any botton.
Can I catch the enter button in any way?
(3,821 Views)
I didn't look at your code, but I'm assuming you're using one of the Key Down events. They have other terminals which you can look at other than the scan code, and they will return the info you need.
___________________
Try to take over the world!
(3,807 Views)
There are several keys that aren't picked up in the scan code, like the arrow keys, backspace, delete, all the F keys, etc.
Mike...
LabVIEW Champion
(3,778 Views)
I'll try that 🙂
(3,759 Views)
