Multicolumn listbox, jump 1 cell down
Cant figure out why this little VI does not work.
Wan't to move edit cell 1 cell down using return.
The edit position is -2,-2 no matter what I do.
(4,130 Views)
Accepted by Michael.Koppelgaard
Try using the Edit Cell event.  Also, according to the help, you have to set the key focus in order to have the Edit Position property to work.
(4,116 Views)
Not sure why you are incrementing.
Modified vi to get the event for multicolumn list box and enables editing , if your requirement deviates modify to increment as  per your requirment
(4,079 Views)
Because the requirement is that when Enter is pressed, the next cell down is editable.
(4,065 Views)
Great i works - thank you 🙂
(4,030 Views)
